  1. helow, i have (monsters ink - filme) and the filme had portuguese/espanish/english , and i used DVDRhelp in bigger than 4500mb
    with smartriper i skiped everything except portuguese PAL and Audio portuguese 6chanels
    i have 2 files now: ac3-file and m2v-file, nothing more...
    they have 3,47GB, do i need still to convert to wav the ac3 file, use DVD britate, and use rempg2 if the 2 files have now only 3,47GB
    if i had DVDit, after the files compressed, it would do .ifo files, .bup files and every thing for me?
    Wath do i have to do with these 2 files, use ifoedit to create the files i need??after compress to mpg? im a little bit confused...
    I hope my english does the work... 8)
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you dont have to do anything but author them to dvd .. if you are going to burn a dvd-r
    if you are going to make a svcd -- thats in the guides in the left ..
  3. Try and get Spruce Up, its a very easy to use DVD authoring software prog. You name the ac3 and m2v the same (ie Film.m2v, film.ac3) and open the m2v file , it will automatically open the ac3 and mux em together. Choose Export, n Write/Title set to build the bup,ifo, etc files.
  4. ok wait it seems like u ripped the dvd to a m2v and ac3 file right.
    and also u stripped the unwanted audio streams and now it will fit on a dvd-r...am i correct
    first u could have ripped the dvd and stripped the unwanted streams and still keep the vob structure using smart ripper or dvd decrypter...and u wouldnt have to remux anything
    ok if u did transcode the m2v stream to make it smaller using rempeg(since u mentioned rempeg) u can use ifoedit to remux the m2v with the audio....just open the movie ifo select remux m2v
